I've never really seen the point to 275s with much better options in 285. BFG and Falken both make 285/70s that weigh 7-8lbs less than their 275 options. Both are going to slow you down a little bit, so I'd go with the lighter option that happens to be a little taller anyway. Both Falken and BFG 285s are around 51lbs each, so with your lighter wheels you're actually right at OEM tire/rim weight.
Pete - 2018 Silver TRDORP w/ KDSS. 2" Fox 2.0s and 285/70r17 Maxxis Razr ATs
