Originally Posted by 03_4x4Runner
I am new to adding pictures so I hope this turns out ok. I removed my 3rd row seats and made a false floor for increased hidden storage. It also saved 100 lbs. Those seats are heavy. The aluminum angle aluminum and plywood came from Lowes. The whole frame and plywood only weigh 4-5 lbs. and can easily be removed by taking out 2 bolts on the shown bracket. The picture with the huskyliner shows the liner I kept from my 03 to show you can not tell from the outside there is storage under the floor. I did not hinge the plywood so that I can open it from front or rear. Smaller items can be hidden out of site by sliding the 2nd row seat forward and putting them in the front opening.
Attachment 125091
Attachment 125092
Attachment 125093
Attachment 125095
Attachment 125097
Attachment 125099
Attachment 125101
Do you have the dimensions for that? Curious how high you had to go to make it flush to the oem plastic kick plate there on the back.
Did you install OEM latches to open the panels up with dual hinges?
