I'm here to suggest owners to try the whole set of
AUXITO LED about toyota 4runner, not only turn signals and marker lights. AUXITO LED headlights and fog lights are liked by a wide range of car owners.
Originally Posted by 2021nightshade4x4
Highly recommend y’all ONLY use LASFIT:
1.) I have personally tested them to be truly anti-hyper flash
2.) Super bright, brighter than any other LED I have tried for signal or marker lights (including JDM ASTAR and Auxito). I was SERIOUSLY considering getting Diode Dynamics “Tail as Turn” kit, so I could repurpose my clear reverse segment as a strobe for inclement weather . The brightness of their turns/hazards makes this unnecessary!
3.) They always have a full housing, they are not “skeleton” LED bulbs which consist of a naked circuit board with exposed chips and solder points
4.) The plug end is ALWAYS secure. On other brands, I’ve found excellent quality that meets the above 3 features, but lacked in having a nodule on the base that allowed the bulb to “SNAP” in. LASFIT has this last critical piece whereas others could simply fall out with gravity and bumpy roads.
