Originally Posted by 99 W/ Kids
I have a 99 runner. I ordered the parts as you have them specified here but the caliper does not fit over the rotor. I am 100% sure i ordered the parts as you have them on here and I double checked them and I received that part number. . Has anyone responded that they had problems with these parts?
I ordered these parts...
2 x OEM Brake Rotors - 43512-0C011
1 x set of OEM Brake Pads - 04465-0C012
Power Stop S2632 calipers from Rock Auto
They do NOT fit together
Also, you've probably already done this, but if it is in fact the right calipers, make sure the rotor is seated against the hub completely. I just did this install and thought it wasn't going to work, but it was because the rotor wasn't seated properly. I even ran a couple lug nuts down (not tight enough) to seat it. Wiggled the rotor a bit and got it to sit flush on the hub and magic.
