Originally Posted by MartinMankat
How much lift would indicate one should use the KDSS spacers? I only lifter mine about 3 inches in front and 1 1/2 in the back to be level.
I haven’t had any lean or issues when off reading.
Thanks for your opinion. ����
two trains of thought here:
1. if you have binding that occurs when you suspension flexes (sway bar to panhard bar) due to extended travel shocks or long travel, then you will probably need this.
or
2. If you are one who believes that your suspension works like a system, and want to get all the pieces of your suspension back into OEM angles after the lift because thats how the suspension was designed (i.e. lean, resetting sway bar, less stress on sway bar bushings, etc), even if its a small improvement by itself, they do add up to improving your suspension as a whole.
