Originally Posted by daronjh
This rubber strip looks removable. (its the rubber strip on the roof, just above the doors) Is it difficult to remove? How do you do it? I assume removing the rails first would be required. Could it be cut, to not have to remove the rail? (weatherproofing/tightness issues?) Is there room under to run wires for lights?
See the attached image. Sorry, I couldn't get the image inserted into the post.
IIRC its glued in a couple spots. itll pop off. use RTV to glue it back down. But yea prolly need to pop the OEM brackets off
