Originally Posted by Turfboy
If I don't want to drop the fuel tank, I could tap the number 1 wire here as this is the Fuel Pump Control ECU. It is not my favorite solution as it is so exposed. It may be worth dropping the tank enough to access the pump wire.
I believe you need to drop the tank anyway with the URD kit to install the new fuel pump inside the tank, unless you already completed that part.
