So with the fuel pump stalled due to my uncertainty as to the trigger wire, I thought I would fool around with other parts of the install.
Today it was the front bumper area. Now the instructions do not tell you to remove the front bumper. Any mechanic who can install the inter-cooler, pump and hoses with the front bumper on is a person with super amazing talent. After a failed attempt to put just the pump on and failing, I took the bumper off. I YouTubed it and found taking it off VERY easy (Except for the passenger Fog light. WTF would you put a shroud over it?
) I took the electrical supply off the driver side and gently laid the bumper down. Then removed the shroud on the passenger side and disconnected the passenger side fog light. The bumper then came free.
Various bits were removed so I had clear access to where the inter-cooler went. The instructions are pretty clear and relatively easy as I successfully completed that part of the install.
I installed the pump and drilled a pilot hole for where a supply line has to go. I connected the pump to the inter-cooler. REMEMBER! There is a plug on the radiator that needs to be removed(you can see one in the picture) and I almost cut one leg of the hose too short.
I am having a bit of a problem figuring out the remaining hoses as there is a description for the hose routing but no pictures in the instructions. But it is late and a beer is calling
2016 TEP, KDSS, ALPRO Apex Sliders, Focal IS690TOY, Old Red's Accessory Meter Display Mod
, Rear Differential Breather Mod, Radium Fuel Surge Tank, URD Supercharger
, Ironman FCP shocks
