View Single Post
Old 11-24-2021, 10:57 AM
4r-4ever 4r-4ever is offline
4r-4ever will become famous soon enough
you do know that you can't just pull it out if it's catching on the inner ridge. you have to loosen the the screw using a screw driver first. the rotor has a hole on it where you can insert a flat screw driver. make sure that hole is around 6 o'clock position and by using a flash light, can see the adjuster. you will have to loosen that first enough for you to remove the rotor.
Originally Posted by truckmike26 View Post
I HATE these rear brakes. The parking brake shoes catch on the rust ridge that builds up over time on the inner disc drum hat and damages at least something when pulling off the rotor.
4r-4ever is offline   Reply With QuoteReply With Quote
