Originally Posted by Simmer
So what about the lower control arm? Is the lower ball joint separate from the lower control arm? Should they both be replaced oem?
Ball joint is separate and the only thing that needs to be replaced (Yes OEM, the 4 mounting bolts too and there are 2 different sets for different years... there's also a "kit" with both L and R which can be a little cheaper ~ all of this is covered in great detail elsewhere). Control arm only needs bushings unless it's damaged or you're modified way past stock... if you can't or won't do the bushings yourself, it might be cheaper to buy a whole new one.
'99 Limited 4x4, Millenium Silver ~
Maintenance Thread
