Originally Posted by ColMntDad
Thanks for sharing your experience. I will give it a go again this weekend with a bigger bar. Having a spare on hand may be a good idea though. I will be doing the fluids from now on.
This is a common problem. When you finally get it off you might want to transition to the metal oil filter housing like so many have. If you break tabs on the plastic housing you can try loosening it with a plumber’s pipe wrench that has wide jaws. Good luck.
