Originally Posted by randy88fj62
A friend gave me the bushings and I read a few threads that say it's almost impossible to swap the rack bushings without pulling the unit.
How bad is it? I've pulled the V8 exhaust manifold, replaced the starter under the intake so I feel confident I could take on a tricky project if it's doable.
If I have to pull the rack then I'd just put in an OEM new one and new high pressure line as the same time. Trying to avoid $1,500 in parts at this time.
You’ll have to pull it out to install rack bushings. I did mine and I have a V8 as well. Wasn’t bad once you get everything disconnected
