View Single Post
Old 12-01-2021, 12:43 PM
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
Originally Posted by shadow247 View Post
SOmeone may correct me, but I have been reading about this setup recently.
The main difference is the ability to use a 3rd Gen Tcase instead of having to source an older Gear driven Tcase.
Originally Posted by Bad Luck View Post
What are the pros of northwestfab's doubler over a taco box?
There are a few pros/cons:
-you can source gears from pretty much any Toyota transfercase aside from the older cases (top shift gear driven tcases are going for 500$+ right now)
-the NWF case is about 2” shorter than the tacobox which makes it so automatics can use them without modifying the gas tank (j shift tcase only, multi mode will still hit tank)
-tacobox you can do 2.56 or 4.7 gears vs NWF box can only do 2.28 (I personally think 2.28 would be fine, I’m running 2.56’s)
-NWF shifter setup seems really legit
-NWF way more affordable and seems to be more in stock/not as long of lead times..
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
