Originally Posted by randy88fj62
Is there a known swap that has been done? I believe the KOH 4Runner used 100 series rack with offset solid aluminum pucks instead of bushings.
I've seen a couple of people using these on Facebook. Problem is its not a drop-in replacement. Your looking at fab work to retrofit the two together.
More common drop-in solution is a gx460 rack. That said, there is a lot of debate as to whether there is any real difference there. My guess from what I've seen described in other threads is that the GX rack has slightly different internals, but not significantly different.
That's why I ended up with an OEM reman from rackdoctor. They last a good long while, and are still an OEM fit and finish. But, I also have no intent to ever go over 33s.
