Originally Posted by JamieG
My 2WD 4Runner needs a California DMV Brake & Light Certificate.
All the lights need to be working and aligned.
I just tested all the lights and the two side white-and-yellow lamps in the front fender (one on each side of the car) don't light up ever. Aren't they supposed to be "driving lamps" and "turn signal" lamps too?
(The turn signals facing directly front and back work.)
It's really hard to get my hands on the bulbs of those two front side lights. One side has the battery in the way, the other the air intake to the engine.
Is there a special trick to get those lights out so I can check the bulbs?
(Where do I find out what bulbs they use?)
The only other lights not working are the license plate lights.
Where do I find what bulb they take and how to remove them?
TIA
Just to check, when you say the marker lights never turn on, have you checked when you lock and unlock with the fob? I don't know of another way to make them turn on.
