View Single Post
Old 12-06-2021, 11:50 PM
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
Originally Posted by woodsby View Post
My wife is the only person that’s ever sat in my car, and she’s only been in it once since I lifted it. The only thing she noticed is it sits higher. I wonder if I need stiffer rear springs, as most of the rocking seems to be in the back. I’m also thinking/hoping extended rear sway bar links and poly bushings will help.
it probably is a good idea to go with stiffer springs, or ideally, match those ALL your springs to your new shocks all around, that will fix your bounciness. Not sure what toyota specs are on those springs. Extended rear sway bar links won't fix your issue, its to fix geometry issues. Poly bushings is just to extend the life of maintenance items.
Getting a bigger sway bar or a OEM non limited sway bar will help with your side to side movement.
I wonder if you can install regular OEM sway bars from other trim..i think thats the direction you should be going.
