Originally Posted by phattyduck
No. Filling the tank is completely passive. There is a vent line from the top of the tank to near the top of the fuel filler neck, above where fuel flows out of the nozzle.
This is the filler neck assembly in a 3rd gen:
One of those is blocked and needs to get cleared out...
Otherwise, the 3rd gen is pretty sensitive to fuel nozzle placement, especially on California vapor recovery nozzles. They must be put in the filler correctly and or it will auto-shut off (from the pump side) very often. The OP is in San Diego, so this could be contributing.
The vent doesn’t go through a charcoal filter? There’s no way… that’s the whole point of an evap system, is to catch fumes during filling and offgassing.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
