Rear window will not lower/raise with key
I just replaced my rear hatch with used door. The only thing I switched from my old door was the key switch. On my old door, the interior switch, key fob and door key switch all worked. Right now, the interior switch will raise and lower the window, but automatic doesn’t work. The key fob will not move the window and the key will not open/close the window from the rear hatch. The key will unlock/lock the doors though. Is there a component that specifically only does the key switch/key fob and automatic functions of the window? I also tried resetting the window and nothing changed. Thanks!
