Originally Posted by Ziegs
So my guy at Toyota is telling me that the Nightshade can't have spacers and that a life would be abut 4k because; you have to remove the XREAS suspension (required when doing lift to Limited's). Was this the case for you? How much did the cornfed lift cost?
You don't have to change anything to install spacers with the XREAS suspension. If you go above a 1" spacer, you will need to use spring compressors I believe. If you're just looking to level the truck then a 1" spacer up front should be all you need, but check with Cornfed on that.
I have a 2010 Limited I bought used that had 3"/1.25" spacers and it drove great until I replaced all of it. Had 33's on 20in aftermarket wheels, but I switched to 17's and 285/70R17's shortly after I got it since I use it to off road.
