Forgot to mention I had tried the fuel system cleaner at least once.
I’ve searched in this a lot, and found (only) one guy with the same problem, and his ended up being a bad injector, so I think you guys are on to it.
IAC also seemed close, I may just try this as well.
I’ll also listen for vacuum leaks, not sure if I’ve tried this yet. No gas smell on dipstick.
I was thinking it might be something like the coolant temp sensor, although this would be a strange failure mode (gets progressively worse) for a sensor but it does seem to check the other boxes.
