View Single Post
Old 01-02-2022, 10:38 AM
Too Stroked's Avatar
Too Stroked Too Stroked is offline
Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough
Originally Posted by osugsxr View Post
Yes for the price it seems to be the best value. Check Amazon out ebay typically 15% off . I’m debating the fog sport white ones or the pro
Based on personal experience, perhaps I can offer some advice. When looking at the Fog versions of the Sport or Pro, remember that although both meet the SAE J583 specs, their actual beam patterns are somewhat different. The Sport has a very tight vertical pattern which makes the maximum use of the lower light output. Because the pattern is so tight, proper vertical aim is critical. Both pods need to be aimed evenly and correctly or oncoming drivers will not be happy.
The Pro model uses different emitters and has higher output, but the vertical pattern is not as well defined. This means there is more "spill-over" at both the top and bottom of the pattern. The bottom is not a problem, but the spill-over at the top can bother oncoming drivers - especially if you're aimed too high. If you like to run your fogs all the time, the Sports - properly aimed - are definitely a better choice.
As for color, the clear lens versions offer slightly higher output compared to the selective yellow. That said, the selective yellow versions offer better penetration in foul weather. Your choice here.
Too Stroked is offline   Reply With QuoteReply With Quote
