? for those with 5100 Bilsteins (clunking?)
For those that have the 5100 Bilsteins, do you get any clunking or other noises? I'm considering a set for my wife's 2020 ORP. The reason I ask is because I had Bilstein yellows on my 2012 WRX and they were loud and clunky across lightly rutted and washboard pavement. Big bumps were fine. I then got Bilstein yellows for my M235. The rears have been fine, but the fronts started clunking within 50 miles; same issue across lightly rutted and washboard pavement. I pulled them off and reinstalled 2 times to make sure I got everything correct. Turns out it's a common issue with Bilstein yellows. I was able to return them to the vendor for a full refund. I've found that Bilsteins are epically good when driven hard, but to have them be so loud and clucky during normal driving has been disappointing. I know the Bilsteins on the 4runner aren't yellows, but I want to make sure the same issue isn't common on these trucks as well. Thanks.
