Originally Posted by bayaz
Hi all,
After my most recent crawling trip, I’ve been having the truck intermittently produce the whole Christmas tree on the dash. Vehicle stability control malfunction, multi-terrain select malfunction, and cruise control malfunction—all appear every time I cold start the truck. 4wd works (both 4h and 4l but not crawl). The lights usually go away after I drive the truck for 5-20 mins and turn off the ignition—next time I start up, no more lights. All the functions work when the lights are off.
Any idea what this is?
I used to have the same Christmas tree pop up about half a year ago (and also after some hard wheeling) except back then 4wd didn’t work. The problem then was a failed front differential actuator, which dealer replaced and the problem disappeared.
Been very tired of these electrical gremlins with the truck. Not what I expected of a Toyota.
Please let me know your thoughts.
My guess would be abs sensor or circuit. stretched dirty etc. Get the abs codes read and go from there.
