Originally Posted by john_brandon
Been searching high and low for this. My rear defogger is not working. I checked everything (pulled rear door trim, checked for frayed wires at the top of the door, you name it) to find that when the defog is activated there is not power at the fuse under the hood. I checked the mirror heater and it gets a reading. I've pulled diagram after diagram, switched a known good relay from R3, R6 to R5, still nothing. Any suggestions?
Attached is the defogger circuit. The body écu controls the defogger function when the ignition is on and the defogger switch is pushed.
