Real Name: Ed
Real Name: Ed
Those two black wires from the projector are for the highbeam solenoid, connect one to OEM common + and the other to OEM highbeam - they aren't polarity specific. Your highbeam indicator should still be operational, no resistors etc are needed.
Red wire from the LED driver to the OEM common + and black wire from the driver to a chassis ground, not the OEM lowbeam -. The drivers have to remain powered with the highbeams and this is the simplest way to do it, and the drivers don't draw as much current as the original halogens so a relay harness is unnecessary.
