Originally Posted by jgue467
Mine did the same, only in really cold (20s here) and only for about 20 seconds.
So i did an experiment using an old turkey baster. Just suck out what you can and replace with fresh, each time turning engine on and moving steering wheel for a few seconds to let fluid mix, then repeat, say about 5 times.
Now you'll have about a pint of fluid that looks something like this, so dark, not even full sunlight goes thru it.
Result, no more whine or grinding noises, do this once a year and it'll be fine. Luck.
Did you clean the filter in the reservoir?
I'm looking to do a PS flush and change and might pull the pump to R&R it all before adding new fluid or just doing a fluid swap.
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Sport 4WD, V6 5-Speed e-Locker->
4WD 4runner Journal Thread
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->
2WD 4runner Journal Thread
