View Single Post
Old 02-16-2022, 09:42 PM
lasfit's Avatar
lasfit lasfit is offline
official vendor
lasfit will become famous soon enough
official vendor
lasfit's Avatar
Lasfit T-Series LED Turn Signal Bulbs - CANBUS Ready/Error Free/Anti Hyper Flash
Are you looking for high-performance LED turn signal bulbs with no hyper flash, error code free, and required no additional load resistors? or want to try the white/amber switchback LED for the turn signal? This post is for you. This post will give you more details about Lasfit T-series LED bulbs and why you should go with the Lasfit bulbs. If you have any questions or want to get LED turn signal bulbs for your other vehicles, please leave a comment below, PM, or email us.
Toyota 4Runner Turn Signal Lights Bulb Size:
1. 2013-2022 Toyota 4Runner
● Front turn signal light bulb size: 7444/7443
● Rear turn signal light bulb size: 7440
2. 2006-2013 Toyota 4Runner
● Front turn signal light bulb size: 1156
3. 2003-2005 Toyota 4Runner
● Front turn signal light bulb size: 7440 OR 4157
NOTE: there are two bulbs sizes for front turn signal lights, 7440 and 4157. Please check your stock bulb size.
Why did Lasfit develop T-Series LED turn signal bulbs?
You may have heard that the CANBUS / load resistor is required when replacing the halogen turn signal bulbs with after-market LED bulbs. Installing low-quality LED bulbs for turn signals, you will get hyper flash or error code warnings on the dash. Many users also complained that LED turn signal bulbs are not bright. Thus, Lasfit developed the T-Series LED turn signal bulbs. The T-Series has higher lumen output, a built-in CANBUS resistor, and NO hyper-flash.
Specification
CANBUS ready, plug and play
Lasfit T-series LED bulbs are designed with a CANBUS system in mind. No extra load resistor or additional wiring harness is required. Plug and play for easy installation.
Higher lumen output.
The max wattage on the T-Series bulb is 24W, and the max output lumen is 2400LM. LED bulbs use less energy and are more efficient than halogen ones. Lasfit T-Series LED turn signal bulbs are much brighter than halogen turn signal bulbs.
Intelligent Temperature Control (ITC)
An excellent Intelligent Temperature Control system will protect bulbs against excessive current and overheating and ensure a longer lifespan.
Safety Protection
A built-in mini fuse protects the bulbs and your cars against the instantaneous high current for safer installation and use.
Worry-Free Warranty
● 45 days money-back guarantee
● 45 days free return policy
● 1-year hassle-free warranty
About Lasfit switchback LED turn signal bulbs
YouTube Video Review
Switchback LED turn signal bulbs are designed for dual-filament bulbs only, such as 7443, 3157, 4257, and 1157. Generally, they are used for front turn signal lights. The switchback LED bulbs are white(in low power mode) and amber(in high power mode). When you turn on the DRL or parking light, the white light will be on. The bright amber will be on when you turn on the signal or hazard lights.
Notice:
If the stock halogen bulbs on the vehicle are dual-filament, such as 1157, and work as turn signals only, with no function of daytime running lights/parking lights. Only the amber light will work on the switchback LED bulbs, and the white lights will not work.
Instagram | Facebook | www.lasfit.com | Youtube | forum.lasfit@gmail.com [909] 758 - 7900
lasfit is offline   Reply With QuoteReply With Quote
