Extended/High articulation CV Axle
Originally Posted by octanejunkie
Install was a breeze, I put the nut on backwards and pounded them in with an 8# dead low hammer; 2-3 whacks is all it took.
I didn't swap c-clips but I did grease them and installed the axles into the diff gap up.
Removing them is going to be curious as there is only a flimsy dust ring, nothing to pry on like the factory axles.
Also, the 40mm axle nut went too deep on the axle shaft, passing the cotter pin hole in the axle by 1/8" plus
Attachment 392904
Rather than go get washers I reused the 35mm Toyota factory nut and castle cap, torqued to 174# with my buddy on the brake pedal and installed a cotter pin and wrapped it up.
Attachment 392905
Anyone want to buy a 40mm 1/2" impact socket cheap? Lol
Sent from my Pixel 4 XL using Tapatalk
Removal is done by hitting the shaft stub with a big dead blow to separate. No need to pry.
ETA, obviously undo the 4 LBJ bolts underneath also….
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
