View Single Post
Old 03-09-2022, 10:33 AM
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Have you got a plan on how to get around the immobilizer on the 2000 Limited 4Runner? If you swap ecu's the immobilizer codes won't match up and you won't be able to start it. I haven't seen any good solutions to getting around that yet.
EDIT: I thought the transponder key amplifier did more than it actually did. Phattyduck is right about swapping ecu's won't be an issue.
