View Single Post
Old 03-11-2022, 02:56 PM
Bad Luck Bad Luck is online now
Real Name: Patrick
Real Name: Patrick
Originally Posted by brillo_76 View Post
Did you replace your oil seals on the rear main when you had the transmission out?
When we did the 1997 limited. Inteplaced all engine seals along with the transmission and transfer input and output seals. I left the driveshadt output seals alone because they are easy to deal with.
I haven’t had the transmission out. I removed what was left of the old transfer case and installed a used one. Everything was covered in oil so there was really no way to know what was leaking at the time. Still debating on trying to find someone to weld the case crack or buy a lower mileage used transmission. The current transmission has a noise coming from the input shaft bearing.
Bad Luck is online now   Reply With QuoteReply With Quote
