Originally Posted by riceandpho
do the tom tom unit a premium jbl system? for the maestro, you just need the odb 2 signal right? and then the the steering wheel inputs right?
try this guide to use the steering wheel adapter wires.
Attachment 394014
It had the TOM TOM unit NO JBL. The shop installed a axxess steering wheel control so they work. I really want the obd2 signal for tire pressure, gauges and codes everything else is currently working. they didnt use the TO1 harness. I dont understand that wiring diagram you posted... If you look at the diagram from the tom tom nothing matches up, they spliced the kenwood wiring to the trucks wiring.
