Real Name: Doug
Real Name: Doug
I hope you've changed to TB/WP at some point, as you're way past the maintenance cycle... Even though I don't live in LA, I have driven in and around LA many times. Summers can be very hot... sitting in traffic with the AC on, this is hard on the cooling system! If I was in your position, I'd do the TB/WP if you havent, and replace the rad. If that rad is original, the top is probably turning yellow/brown, a sign the plastic is degrading. As these rads do fail from time to time--- luckily its not an auto, as you dont have to worry about the "pink milkshake" ... Of all the generations, I think its generally accepted the 3rd gens are the most reliable! You do not have alot of mileage on yours, I've seen 3rd gens going strong at 300-400K. I myself have 335k, and I do all the maintanance--- I wouldn't hesitate to go on a 500mile road trip tomorrow. Maybe the std shift may get a little tiresome after a while. All the later gens get much worse gas mileage...
Good luck!
1998 SR5 3.4L V6 Auto... Pretty much bone stock...aside from the Tundra brakes, OME880 and OME906's in back all with Rancho 9000XL adjustable shocks ... "Livin' the dream in the Canadian Okanagan!"
Electronics/Telecommunications Engineering Technologist
