Originally Posted by octanejunkie
Where is the best place to intercept the fuel pump power for a kill switch?
Sent from my Pixel 4 XL using Tapatalk
If you just want to shut off power to the fuel pump, you will need to do so in the driver's side section between the kick panel and the rear seat. This is accessible under the rocker trim and the carpet under the back seat. Otherwise the Fuel Pump shares the power source(EFI Fuse) with ECM, CO relay, MAF, 02 sensors blah blah blah.
