View Single Post
Old 04-01-2022, 10:10 PM
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
Dexron III ATF is the correct fluid. I use Mobil 1 synthetic ATF Dexron III compatible.
Looks like it’s definitely the cap leaking, make sure it on there good.
Turning the steering wheel lock to lock with the motor not running is how you bleed a power steering system. It is also part of the process when changing the fluid. At least one of the methods.
1000MPH is offline   Reply With QuoteReply With Quote
