I had this TSB performed at the dealer on my 99, the VIN fell into the do everything list, and they forgot to mention the P.A.N.T bulletin 00-01, and zeroed out my OD and made me sign off of the change, anyone have a copy of the PANT bulletin? it was pretty annoying to read this after the work was completed. And running out of fuel is a safety concern passed off as a TSB on the customers dime for those that got known faulty parts installed at the factory.
