Originally Posted by Juppers
Are you using the to1 harness or just adapted the manual wiring instructions?
The reason I ask is the manual instructions leave out a wire or 2 and use different pins to the maestro for some connections, which the harness firmware accounts for. It is only so they can sell the harnesses, not because the wiring would be too difficult to do manually, and if you point it out on their forum your post will be deleted. Sadly the schematic for the to1 harness isn't posted anywhere i know about.
interesting, i might need to buy this module and harness to disect and figure out what is there and not.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
