Originally Posted by Logansky
I finally got around to installing my skid plate. Watched all the you tube videos, cleaned out the threads, did everything right. Did it with vehicle on ground, stock TRD Off Road suspension. Tight but manageable.
EXCEPT I had a heck of a time man handling it into position and starting the bolts. Sort of dreading the next oil change when I have to remove it and do it all over again.
Any suggestions or little tricks to make life easier would be greatly appreciated.
Logansky
Ensure you use the retainment washers on top of the spacers for the front bolts. I also use an impact so it can spin while I hold the skid in place with my other hand and knees. After you do it twice you get the routine down.
