Originally Posted by Bonanzajellybean
I ended up getting one from talons garage Talons Garage | Catalytic converter protection |
Works ok, doesn't exactly line up with the transfer case and I ended up using a bolt buster to bend the transfer case crossmembers to get a more snug fit, but now I sleep better without fear of cat theft, which is rampant here
I installed the Talons Garage plate as well, and I also had fitment issues. I had to widen the mounting slots with a dremel on one side of the plate to get them all lining up properly. You could clearly see they were off center. Other than that, I'm happy with its coverage and don't worry about it while it's parked.
