Wheel hub stuck to knuckle
Hello all!
Replacing my wheel hub assemblies as my front wheel bearings both were in need of swapping. Got the drivers side one done with minimal hiccups. Passenger side is really giving me a run for my money. Will post pics in a little when I get off work, but I cant seem to get the base of the hub separated from the spindle/knuckle. Ive got the bolts holding it in all the way out, cv is loose, and now the bearing appears to have separated. Ive soaked it in pb blaster over the last two days, tried hitting it from all sorts of angles and different hammers, tried heat. Cant get a gap to appear between it and the dust shield. Close to pulling the knuckle out and bringing it to a shop, but wanted to see if anyone had any advice before then. Thanks!
