Sustained high speeds definitely calls for higher pressures....this lowers sidewall flex which builds heat.
I recall my Mercedes had two pressures specified on the inside of the fuel door. One was for driving above 100mph and the other for below. I always kept mine at the higher number. It was about 10 psi higher if I recall.
Even though 85 is not 100, stands to reason a suv tire builds heat easier than a low pro sport tire.
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
