Here's what I purchased:
EBC Brakes USR7237 USR Sport Slotted Coated Brake Rotors, 2 Wheel Set EBC-USR7237
Dynamic Friction 1214-0976-01 Heavy Duty Semi Metallic Towing Brake Pads With Hardware DFC-1214-0976-01
Stoptech 950.44007 Stainless Steel Brake Line Kit, 2 Wheel Set STT-950.44007
Stoptech 501.00001 600F Brake Fluid
If I am to upgrade to the 5th Gen fronts (eventually rear), will I now need to replace the already installed/new rotors and pads to fit the 5th Gen-sized calipers?
**Looks like I'd need rotors/pads/calipers if I went 5th gen...I'm not able to buy new rotors as I've already installed my EBCs...are the Powerstop calipers worth owning for perhaps a little longer life than a potential reman caliper? Arrrrgh! I wish I did a finer degree of research on this!
2005 T4R Limited V8 Dorado Gold Pearl|'06 Headlight/Taillight Update|5000k HIDs|VSC-Off|Husky-Lined|HCF Delete||IAP By-Pass|TPS By-Pass|AFE Pro Dry S|Gibson Cat-Back Side-Exit|Pioneer AVH3800BT|Sprint Booster|BD SSPro IFLs|LEDs|ICON 2.5+|SPC UCAs|TE/FJ Wheels|255/80 Cooper ST MAX|Spidertrax 1.25|Custom-ish End Links|Custom Perkins Roof Rack|40" LED Light Bar|SW Color-Matched Front Bumper
