Originally Posted by Power24-7
Sorry for reviving an old thread but this is the first one that came up when I searched. Anyway.... I am normally a do it all my self kinda guy but thier price for everything assembled seems very reasonable when compared to purchasing all the adapters and dash kit separately.
So, for those of you that installed the Trail Grid Pro kit are you still happy with your decision?
While the TGP looks like a fine kit, I don’t believe the module they use, unlike the Maestro module, will pull OBD codes (trans temps, coolant temp, check engine, tpms, etc.). If that stuff is important to you, you may want to make sure whatever setup you decide on uses either the Maestro RR or RR2 (if you want to have 3 programmable outputs; ie to control lights thru your head unit).
I asked them about this, and at the time it didn’t do OBD readings.
