Real Name: Ron
Real Name: Ron
My thoughts on this problem (the connector being discussed) is that if I experience it and a pin is broken not going to try and repair as I think you may be able to replace the entire harness by dropping trans pan, disconnecting harness from all solenoids and pull it out and then thread a new harness in.
I've watched some rebuild videos on trans and it appears worth a try to me versus trying to replace a pin.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
