Originally Posted by TW44LR
Gotcha I’ll try to test it this weekend. If it tests bad should I go ahead and replace them all or just the one? Any good sources on where to get them?
With the suspected injector pulled out of the rail connect 12 volt power source to one terminal at the connector and ground wire to the other terminal. The injector should click each time the ground wire is connected and disconnected to the terminal.
