Originally Posted by Spiker Engineering
I just took my brackets out. They put the sway bar links at a really poor angle, like this (look at the bushings!):
Without the relocation brackets, the geometry is much better:
The only advantage I see to these relocation brackets is that they create more clearance between the sway bar and the e-locker actuator. But then again, a lift does not change the arc in which the suspension travels, only the resting position - so if Toyota thought that there is enough clearance at factory height, that should still hold with the 2" lift (it's the same as 2" of suspension travel from stock).
What end links are those?
