her are some pics. from bottom to top this is how I secured:
m8 x 40mm bolt, m8 fender washer, crossbar, m8 fender washer, lock washer, nut, 1/8" aluminum flat attached to case, case plastic, EPDM washer, nut. when I remove the case I have the tops of the m8 bolts which I use those plastic screw covers to protect the threads
if the cases are perfectly centred the 1720s are about the exact length of the side rails. I had to slightly move to the rear so the front edge didn't pass over the back edge of the faring. this also doesn't cover the mounting slots in the faring in case I want to use them. if you get anything longer than the 1720 you will lose your slots in the front faring
