Originally Posted by Brian.
the item you linked looks like just a mast intended for the automatic motor, and may be exactly what you want/need. But the Taco whip conversion is a Completely different beast, you replace everything from the head unit (plug that fits into the HU, wire though the firewall, mount the new mast on the inner fender) on out to to the antenna you see. I did it, it was a ~2 hour job mostly due to my meat mitts being oversized and not fitting into tight places well. It's annoying, not difficult. Quality is outstanding though, as you'd expect from a Toyota part.
I suspect the easy solution is the mast you linked, but I don't know how much easier who who knows about quality or longevity. Want to do it twice?
What do you mean? The antenna doesn't require the corresponding headunit whatsoever, i used it with the OEM one for a month or so, unless im misremembering. The only difference between the two units is backlight color and ours having plugs for an amp and secondary antenna .Should take you maybe 30 minutes max to swap out the masts themselves, wouldn't exactly call that a "beast"
Y2K Highlander
Millennium Silver 3.4L auto @ 320k and climbing
