View Single Post
Old 05-29-2022, 11:02 AM
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Assuming you have a 4wd you can confirm it’s the rear driveshaft by putting the transfer case in 4wd high and removing the rear driveshaft. You will essentially be driving around in front wheel drive and it will not cause any damage to any drivetrain components. If you remove the rear driveshaft and the vibration goes away then you have found your culprit
