Real Name: Ron
Real Name: Ron
I don't know what year you have but my '03 LTD. if you want to bleed the rears : start the engine, have someone press the brake pedal and hold it and crack the bleeder screw and it should pump out a nice steady stream. If not you have a problem. Make sure your brake reservoir is filled.
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
