Originally Posted by Toystory2
I need to loosen the connector labeled 1? I saw another nut on the caliper (2)
so wanted to make sure.
Loosen the one closest to the caliper #2, it will be easier to get lose, you can use a regular boxed end wrench or a socket on that one.
Originally Posted by 4r-4ever
that's not where you bleed it. the one on the right is where you stick a hose and bleed it.
He’s try to see if there fluid flow at the caliper, he’s not trying to bleed the brakes at this point.
